3.4L help
Okay i changed my water pump today put everything back together, Now there is coolant bubbling up in the jug, and water seems to be cooking in the front 3 spark plug holes, Im assuming headgasket?...
Sure sounds like a headgasket. I would imagine if it were an intake gasket it would suck the coolant down, not push air into it.
Sure sounds like you didnt bleed the coolant system correctly and have air in the system, end result is overheating in spots and coolant boils off and get more air in the system.
How does one bleed the system the right way?....Any info would help as im pretty clueless...
