94 CS Convertible. Interior lights do not come on except at light switch
This problem just started: If I use my clicker to unlock, the interior lights do not come on.
If I open either door, the lights do not come on.
If I turn the switch on for the interior lights, they do come on.
Would you suspect wiring from the door to the body? Or, could it be the driver's door window/lock controls?
Any ideas are appreciated.
David
Possibly bad door triggers? Its a cheap and easy thing to try.
Thanks. Odd both door triggers would go at the same time.
  • 1 month later...
Problem found: I took the light switch from the dash and the contacts looked pretty bad. Brush them up and cleaned them best I could- problem solved. Hope it helps someone.
