crazyd Posted June 19, 2011 Report Posted June 19, 2011 I'm swapping out trunklids, anyone know how to swap the lock cylinders from old to new? Quote
Psych0matt Posted June 19, 2011 Report Posted June 19, 2011 (edited) who are you, and where are more pictures of that beautiful car? EDIT: Nevermind, found them :-3 (sorry, I'm not sure about the lock cylinders ) Edited June 19, 2011 by Psych0matt Quote
Crazy K Posted June 19, 2011 Report Posted June 19, 2011 drill out little rivet on the clip below the lock(sometimes you can snap it off with a flat head screwdriver). remove clip. sometimes the clip does not come out because of a little snap tab that jambs, make sure to remove the one from the dead trunk lid first to see what it looks like, if it jambs it often requires a little bending of the hole in the lid that the clip passes through right where the offending tab is. Pull locks out. remove the rivet remains from the hole (usually knocks right in). switch locks. use a screw in the rivet hole. done, unless you want to go up and lubricate the lock while it is out. Quote
crazyd Posted June 23, 2011 Author Report Posted June 23, 2011 Just finished installing it, didn't have to drill anything out. There's a large clip that hooks into place to hold in the cylinder, remarkably easy. Hard part was splicing the wires and getting it aligned with the body. I've had the flimsy luggage rack on mine and never liked it, so this was an upgrade to a 94 SE trunklid & spoiler, vast improvement. Thanks to all! Quote
rockfangd Posted June 23, 2011 Report Posted June 23, 2011 that is one hot color. Is it factory? Yeah the lock cylinders are cake. Most time the rivet just pops off and you just slied the clip down enough to pull the cylinder out Quote
crazyd Posted June 23, 2011 Author Report Posted June 23, 2011 Thanks, no it's not factory. I had it redone in '09. http://www.w-body.com/showthread.php/42159-Best-GP-color-I-have-ever-seen Quote
iroc2 Posted June 25, 2011 Report Posted June 25, 2011 did you keep it debadged? looks perfect like that Quote
crazyd Posted June 28, 2011 Author Report Posted June 28, 2011 I still have the "24 Valve V6" badges sitting in the car waiting to be painted and reapplied. I got some of the paint to do them so I've been thinking about it. Quote
