GaPrix Posted June 14, 2011 Report Posted June 14, 2011 So while I"m idling, sitting at a stoplight, wherever. My rpms will dip up and down. It will drop then the engine will pickup attempting to stabilize i suppose. Sometimes it'll drop so low as if the engine will acti like its starting to die then surge up to say a 1000. Everything else seems normal while actively driving. Quote
xennith Posted June 15, 2011 Report Posted June 15, 2011 check out this thread. I started it. I'm still having the problem, but it seems to improve slightly every time I fix something. The only thing I know for sure is that my fuel pressure is about 8-12 lbs too low. I just replaced the filter so the only other things I can think of is the pressure regulator. There are a lot of suggestions on there about what to try. good luck http://www.w-body.com/showthread.php/50471-3.4-Idle.-Suggestions Quote
GaPrix Posted June 15, 2011 Author Report Posted June 15, 2011 Thanks, I'll can check on those, filter could be clogged probably time for a change anyway. Quote
leadfoot2 Posted June 15, 2011 Report Posted June 15, 2011 Had that same problem with my Impala. First tried cleaning Idle Air Control Valve (IAC) with slight improvement. Then I replaced it and also cleaned my throttle body. Hope this info helps you. Good luck Quote
GaPrix Posted June 16, 2011 Author Report Posted June 16, 2011 I already had cleaned the IAC made a tremendous improvement (it was solid black), may try a j/y one and see if its any different. Quote
xennith Posted June 16, 2011 Report Posted June 16, 2011 I replaced TPS and IAC and now fuel filter, all new and it still isn't perfect although each one made it slightly better. Quote
gp1991 Posted June 16, 2011 Report Posted June 16, 2011 mine did this since i got it, and then it got so bad to the point where it would drop so low and die, and i replaced the the fuel pump relay and it has not come back for months and it fixed it instantly. im not complaining lol, but before i replaced that i got a ses light for low voltage to the fuel pump or something like that. Quote
GaPrix Posted June 21, 2011 Author Report Posted June 21, 2011 so would a crack in the uim cause this? Quote
GaPrix Posted July 1, 2011 Author Report Posted July 1, 2011 Replaced the uim and it seems to have nearly fixed the issue, its been so long that i've had a steady rpm gauge its kinda wierd. There is just a very slight change at idle now, say 700-600 i'm assuming is normal (Idling at operating temp for about 15mins). I did come across some liquid assuming oil on the tps connectors, not sure how that happened. And I seafoamed it too. Quote
GaPrix Posted August 6, 2011 Author Report Posted August 6, 2011 Okay, replacing the uim didnt fix it, it started back maybe 1.5 weeks after install. This is everything I've done, seafoamed - (oil, intake, gas) changed oil - royal purple, fuel filter, cleaned iac and the other one tps again. Now it idles right and funs better than ever. I'd guess it was a clogged filter. Quote
