Night Fury Posted June 13, 2011 Report Posted June 13, 2011 (edited) Yesterday- Ran perfect. Today- NOT SO MUCH. Kenny took it down to work at 9pm last night and it was running fine. When he got off(5am) he went to start it and it acted as if it was out of gas. No huge surprise there, the odo had 300 miles to the tank and our fuel gauge is broken. So I dumped 3 gallons into it..... no dice. Still running like ass. I limped it to the gas station, and filled up. 14 out of 18 gallons total, so it wasn't even empty........... Some things it's doing; -Will idle almost perfect, until you tap the gas to get it to stay at about 2k rpms. Then it cuts out repeatedly -Runs perfect at WOT -When coasting on the highway, it won't actually 'coast'. Hard to describe. I shifted into N and it died instantly.... Repeated twice. -Strangely enough, it DOES boost, but nothing shows on the boost gauge........ -NO CHECK ENGINE LIGHT. And before you ask, yes the light works. Video: Thanks for any help.... Edited June 13, 2011 by Night Fury Quote
tornado_735 Posted June 13, 2011 Report Posted June 13, 2011 Sounds like maybe the TPS has taken a dump. Do you have a way to ohm it out? Someone here might know what the specs are. Quote
alec_b Posted June 14, 2011 Report Posted June 14, 2011 TPS is a variable resistor, you don't ohm it you do a voltage sweep. I'd still scan it and see if there's any pending codes, just in case. Possible MAF? Quote
Addicted to eaton Posted June 14, 2011 Report Posted June 14, 2011 IIRC he is drive by wire. yes sir. Cps goin bad? Quote
Night Fury Posted June 14, 2011 Author Report Posted June 14, 2011 yes i am drive by wire and i unplugged maf while running and it died. Quote
Night Fury Posted June 14, 2011 Author Report Posted June 14, 2011 would the cps do that so suddenly and it turned over but doesn't want to start with the maf unplugged... Quote
Addicted to eaton Posted June 14, 2011 Report Posted June 14, 2011 CPS would do it worse iirc, weird my car would run the same with the maf unplugged/ Quote
Night Fury Posted June 14, 2011 Author Report Posted June 14, 2011 CPS would do it worse iirc, weird my car would run the same with the maf unplugged/ Yeah my brother has a 3.8 camaro that the maf went bad on.... Wouldn't run. Unplugged the MAF.... Ran fine. So I don't know what is up with that or if it is even any concern with the more computer-controlled S3 L32 Quote
birdman Posted June 14, 2011 Report Posted June 14, 2011 Yea my gs ran fine with the maf unplugged.. umm have you unplugged the tps at all yet? Quote
alec_b Posted June 14, 2011 Report Posted June 14, 2011 Cant unplug the TPS if it's DBW. Maybe an accelerator pedal position sensor took a shit? Quote
Night Fury Posted June 15, 2011 Author Report Posted June 15, 2011 Cant unplug the TPS if it's DBW. Maybe an accelerator pedal position sensor took a shit? ORRRRRRRRR it could be a stupid vacuum tee.... LOLOL Quote
urbex Posted June 16, 2011 Report Posted June 16, 2011 -Runs perfect at WOT Uh, just drive WOT. Problem solved!!!!!! Quote
Night Fury Posted June 16, 2011 Author Report Posted June 16, 2011 WIN! Although that might create other problems, such as how to untangle the mass of metal from the Jersey barrier at the intersection of US59 and US36 LOLOLOL Quote
