Factory cheap alternator upgrade
xtremerevolution
I could put a jy unit on, but with a rebuilt one, I know it'll last a while without being a question of when.
I guess it doesn't matter too much to me. I can change my alternator in 5 minutes blind folded and all of my alternators have lasted a very long time.
This thread was more designed so that people can get a higher output stock fitting alternator for dirt cheap. Obviously anyone can spend the big money on a built alternator for their cars, but if I can get good mileage out of a junkyard alternator, I can spend the remaining money on something else.
Link to comment
Share on other sites
there is no cs130d's that will bolt on my car though, out of the JY.
2.8/3.1 guys need a modded case to make it a bolt in. What I should have done is made a thread and done a write up when I did that.
Edited by Garrett Powered
Link to comment
Can't use the bracket bits off the D?
Link to comment
if it is possible, I have not yet seen pics or even heard of anybody doing it. I would like to see someone try because then we might see more TGP's and other W's with D's in their engine bay. just like it would be nice to see more people running CS144's or similar chassis alts on 3100/3400 cars. or if someone installed the minivan bracket on a 2.8/3.1 and ran a big chassis alt, I would love to see if that is possible.
you know how those alts have a split case though, so there is two sides. well, if you order a specially clocked case for the one side (wish I had a part number) and machine off some of the aluminum in a special way with a lathe, then it will bolt in on stock brackets. I bet you could use a grinder and get close enough but this shop I go to has no reason to take a chance with hand held tools.
Link to comment
  • 3 weeks later...
ok guys, sorry I just went and read everything on here and I've been doing audio/electric in cars for a while now, this is what i've come to know as of yet
the cs 130D is not exactly the cream of the crop...I had a factory one in a car with 140k I put in a small system, 2 audiobahn aluminum 12's and a 800watt audiobahn amp, with 1 farad cap, and i fried it, next step was a 220AMP...well this one failed inside a monthe with 3 audioban alum12q's and a 1000watt rockford amp, 1000watt generic amp and 3 farads to back it up, as well as 0/0gauge main wire and 4gauge feeds to the electrics, topped with 2 seperate 0/0 gauge grounds-this was just under the hood....the rest was feed through a 0/0 and 0/1 gauges each component having it's own ground, and i'm not so sure you can get above 105amp factory...that i don't know, i went straight to aftermarket, but my lights still would dim.....now I have a factory power rebuild on my oem alt. but I am running just the 1000w amp rockford 2 farads and 2 rockford p3's and its definately not near enough, but my second rebuild on the 220A should be here in about 2 weeks, also a capcell is goign to be added...maybe that will help out. either way the design is flawed and unless you don't wanna go big with your system its gong to be a never ending process.
the cs144 is pretty tough as of yet in my mind, I have 2 LTZ's both have had systems in and out ranging from my smallest 500watt kenwood and 2 RF10's, upto 2 JL 12 W6's and a 1000.1 JL AMP no wiring upgrades, a 0/1 gauge feed to a 600amp capcell then to amp, and a 0/0 ground, both have been replaced one time, just with a palladium rebuit one from advance, wait I take it back my 98 is currently running on it's third. i'm going to try 3 RF p3 12's on a 1000.1 RF amp and a 2 farad cap and see what happens
as for the two being interchangeable is a question i cannot answer
thats my experience with my own personal vechicles where I know what happened....i.e. not a customers..
the wiring upgrade is definately where you will see the most drastic improvement, and I know this sounds obvious, but MAKE SURE all your connections are good, CLEAN (espicallly the grounds), and solid
the charging wire
the line to the starter
the ground off the batt
....now you can and probably should add in these (I did)
line to fuse blocks
ground off the engine block or head depending on the car..both
FUSES/CIRCUIT BREAKERS ON ALL MAJOR HOTS..i.e. the charging wire
hope this helps someone
Link to comment
the lumina LTZ comes with a 140 amp cs144 and it should be a perfect match even for the GTP's, i'm using it for my top swap
are you sure? I am still trying to find out more info on this is why. stock cs144? I would like to see a pic of this.
wait, no, you have a 3800 with a cs144? never heard of that.
Link to comment
  • 5 years later...
Police package on Impala too?
I would assume so. I know the H bodies had bigger amped alternators on their 3800s. I forget if they were 120 or 140 amp though. I know the Eldorado had 140 though.
Link to comment
  • 3 years later...
