Rad supports
Hi guys, been slowly putting my 95 GTP back together. Got the subframe reinstalled and steering rack last night. Was putting in the rad last night and realized I wasn't sure where to install those 2 supports with the 8mm bolts. The ones that bend out then back in with a piece of plastic on the end. Also, wasn't sure where the 2 rubber pieces went. Its been awhile since I removed the rad, so I've just forgotten.
I think you mean these.
One is by the filler neck and the other is by the upper radiator hose.
They bolt up at the top of the core support and are on the ends of the radiator.
Those would be the ones! Thanks :) Any idea where the 2 rubber bushings go? Do they go at the bottom? I don't mean the round ones that sit on each end at the bottom. I have 2 rectangular-ish ones.
Well, there are no rubber bushings where it bold into the core support. I'm pretty sure they go where the meet the edges on the radiator. Look at the first picture I posted. I see a rectangular bushings at the end of that metal support.
  • 3 weeks later...
This may have been resolved. But, I had the thought that the AC condenser has rubber cushions on all four corners.
Yes, those rubber cushions are from the condenser which has been removed in my case.
