Crazy4408pac Posted June 7, 2011 Report Posted June 7, 2011 Have 98 Monte LS. How hard of a job is it to replace the brake light switch? What's the procedure? Thanks Quote
Crazy K Posted June 7, 2011 Report Posted June 7, 2011 Why do you think the brake light switch is bad?????? Diagnosis: Does your third brake light work? yes? it is the Turn Signal Switch. no? change the bulb and try again. Install fresh bulb in third brake light does the third brake light now work? yes? it is the Turn Signal Switch. no? make sure the contacts for the bulb are clean and try again. let me be more serious... READ: http://tss.likeabigdog.com/ Quote
Crazy4408pac Posted June 8, 2011 Author Report Posted June 8, 2011 I know it's the switch because it's sticking on. When I pull up on the peddle, the lights go out. Just need to know what it takes to change the switch. Quote
jeremy Posted June 8, 2011 Report Posted June 8, 2011 I know it's the switch because it's sticking on. When I pull up on the peddle, the lights go out. Just need to know what it takes to change the switch. Quote
55trucker Posted June 8, 2011 Report Posted June 8, 2011 If the switch *opens* when you manually pull up on the brake pedal, why isn't the pedal returning to its normal *off* position by itself? Quote
White93z34 Posted June 8, 2011 Report Posted June 8, 2011 or the switch just needs adjusted, the whole body of it is threaded, unplug the connector and turn it back a few turns and see if it still does it. Quote
94 olds vert Posted June 8, 2011 Report Posted June 8, 2011 ^ That does work. I had to do that on my car. If I pulled up on my brake pedal the brake lights would go off. Quote
Crazy4408pac Posted June 8, 2011 Author Report Posted June 8, 2011 Yep, not the switch. I looked at why the peddle was't returning and discovered alot of crud built up around the pivot point. Blew all the crap out and sprayed some silicon on it and no more problem. Thanks everyone for the info. Saved me a big $3.75 for a new one. Quote
