3100 fuel pump enough?
95' monte with L67 running 3100 fuel pump
is it up to the task?
The cutty still has the stock 3100 FP, but then again, I've done absolutely NOTHING in means of perfeomance (bolt-ons, cam, etc.) It's 100% stock. So if you plan on keeping the L67 stock, I can tell you the 3100 FP WILL be enough. (And yes, I've scanned it through HP Tuners, it's not leaning out in high load situations)
What is your fuel pressure at WFO/Max RPM?
You have adequate fuel pressure, you have enough pump.
