So... I have a 99 lumina that has starting squealing in park and nuetral only. Once you put it in drive or reverse the squeal stops. Any ideas? It still engages park just fine so I'm not sure if its the parking pawl. It doesn't sound like the drive belt slipping either. It makes the noise when you first start the car and when you go from drive to park as well...
What about a bad ignition cylinder? I read that it could cause the starter to continue to turn over when in park or neutral.
