DRL's and parking lights
Are parking lights supposed to come on with the Daytime Running Lights?
thanks
the car is a 95 monte carlo with complete 99' monte carlo wiring harness
swapped in. everything but the fuel gauge and the DRL's work fine
No. Not ever. Are you sure you don't just have the highbeams on; since it uses both DRLs and HLs. (runs the highbeams in series/ 6V while in DRL mode).
alright... i get in the car. put my key in the ignition.
(headlight switch is off) turn the key on,.. DRL come on,
but so does the dash lights, parking lights..
if i turn the parking lights on (at the switch) there is no change (like they were already on...)
turn the the headlights on and the DRL's go out, headlights come on.
highs / lows / DRL's all seem to work but the DRL's seem alittle bright for 6 volts???
This may seem obvious but make sure that nothing is covering up the light sensor in the dash. If it is unobstructed it may be defective.
hold on.... maybe nothings wrong?
will the parking lights come on by themselves when it is dark out??
cause i just went out to mess with it..(daytime)
turn the key on got DRL's with no parking lights
was messing with it at "night" at first
never had DRL's before...didnt know how they functioned.
the car didnt have that feature before i swapped everything out
Yes, the parking lights will come on at night by themselves as well as the dash lights with the DRL system from a 99 Monte.. In the daytime, they will be off... That is what the "eye" on the dashboard does, tell the lights if it is dark out to come on...
cool. finally figured this out tonight.
makes me wonder....what is the point of the headlight switch then??
Manually turn the HL/TLs on..
In Ohio, your headlights and taillights have to be on before the DRL will actually kick them on.
He's saying that you are legally supposed to have them turned on before it's dark enough for the DRL system to turn them on automatically.. In Missouri you are supposed to have your lights on if its raining as well, so most of the time it isn't dark enough to trigger the autolamps, so you may have to manually turn them on as well in this case..
