I adjusted the toe and it drives a lot straighter. Still squeals, but it's not completely unpredictable like before
Just doing some reading after searching for alignment. Have '00 Intrigue, rear suspension got rusted up pretty bad and I had to replace one bent lateral arm so I bought the whole shootin' match at salvage and replaced everything! It was actually reasonably close as-is, which was pretty incredible, but took to Firestone and they are telling me that the camber is off and it needs a camber kit. Said it was .5 degree or 1 degree off,, is this enough to worry about.
Anything over .5 degrees camber is considered tire wearing. However negative camber is good for handling.
I wouldnt worry aboot it, just keep your tires rotated every 6000 miles and you'll be fine.
$20 at Graff in durand!~
Why so cheap? At a dealer....this confuses me....:think:
