J Posted June 3, 2011 Report Posted June 3, 2011 what do i need fellas? Been out of the game for too long, and now that i am driving it i hate the squeaking i get over every tiny bump. I know the struts are GONE. Should i have a rubber or poly isolator under the spring or should it sit on the spring perch (aluminum threaded nut). I was under there tonight with it in the air spraying PB blaster on the trailing arms to finally put on my gmpp arms (in garage for 4 years). The car also misses slightly like it has a little cam in it. WTF? It seems sometimes when i hit the gas to take off from a light it also almost dies for a split second and then takes off and drives fine. LMK GUYS. Jay Quote
19Cutlass94 Posted June 3, 2011 Report Posted June 3, 2011 As far as coilovers go, youll want something at the top and bottom of each. However since I rebuilt my FFP coilovers, I never really got rid of all the niose... I hope you can. I need to rebuild mine, but dont wanna pay for another alignment. Quote
Psych0matt Posted June 3, 2011 Report Posted June 3, 2011 Check your fuel injectors, I had that problem for the entire time I owned it, until one injector died, and I replaced all of them and now it's fine. Hopefully not something like that, but keep it in mind. I know adam had a little bit of rubber where they meet to quiet it down. I need to do that on the bottom of mine where the spring sits. Quote
