I'm in need of one. The ones I have only go as far as the fans and I believe the fans aren't coming on at all along with the compressor clutch. I think it is either a ground issue on the control circuit but could be something else. What I've done so far is check the contact points under the clutch relay. Power is there but ground is reading high in the Mohms. I jumped points 30 and 87 and everything comes on. I swapped fan and clutch relays and still wouldn't work but I'm not sure if the fan circuits intermix with the ac on that side making it pointless to switch them
Nm pulled the codes and I got a code for low pressure guess its time for a retrofit..... :confused:
