What could set a P0172?
SES light popped up while I was sitting in traffic yesterday, it was a very humid day ambient temp were around 86*. Stayed on for a couple hours but was gone by the evening.
I pulled the code this morning at work, P0172 System too rich Bank 1. Quick search of identifix seemed to point towards a failing MAF, but the first tip was to check the MAF screen for debris, which I did and it was clean.
I didn't take the time to check trims with the scanner, but it never ran any different and the light like I said went off on it's own. I did check the FPR and it's not leaking.
So MAF is one idea, I'm thinking maybe a lazy O2 might do it, sending false rich readings to the PCM. Anything else to check?
It's a cone filter that was on the car when I got it, it's clean and not over oiled that I can see. I did blow it off with air just in case.
Get a scan tool on there, and see what the trims are.
Seeming it has a cone filter on there, remove and clean the MAF. Cone filters = dirty and oily MAFs. Even the slightest bit of oil that you cant see will mess with the readings. I always cleaned my MAF every oil change for that reason with my cone filter. Cause if I didnt, around the 5000mile mark, my fuel trims would start heading rich...
Ditch the oil style cone filter, and grab a AEM Dryflow unit.
AEM dryflow, check. I never really liked the oiled units anyways, I get SO many issues at work because of dirty MAF's. I have the day off tomorrow, I'll stop up and throw the scanner on it and see what my trims are. I seem to remember though, last time I had the scanner on it for my cam sensor code that the LTFT's were somewhere around 7%, even though the STFT's hovered right around +/- 2%.
IIRC its not until 15% minimum that it will set the code, and I think it has to sit at 15% or more for a fail amount of time.
15% sounds about right, I can't IMAGINE that it's be running that rich for that long and not start missing, or smelling terrible or blowing black smoke. I'm glad it went away though.
Around 20-25% is where you will generally notice something is way fuxored:lol:
However, its prolly a MAF issue, so it prolly wasnt really running rich, it was just going off of what the MAF was reporting to the PCM.
That's what I was thinking. I'll pull the MAF again and clean it after I check the trims and reset the ECM, and see where my trims land after that.
Got some numbers:
Idle- STFT hovered between +3 and -3
LTFT was sitting right at -7
MAF was at 3.79 g/s 2111 hz at idle
2500 RPM - STFT -3 to -7
LTFT -4 steady
MAF 11.25 g/s 3315 hz
Anything look off?
