Gen 1 window lifts
I need to put a new driver's side window motor in the 1996 Grand Prix coupe this weekend, it looks like. Is it likely the regulator is in bad shape and causing it to fail, or can I just grease the hell out of the regulator and expect it to be ok? thanks
The motor is probably weak, but you should always grease up the regulator while you're doing that.
