johnny404 Posted May 22, 2011 Report Posted May 22, 2011 according to my research i can put a 2.25 turn lock-to-lock rack and pinion in my cutlass convertable,the same one that the turbo gr prix uses anybody done this and how did it go? Quote
alec_b Posted May 22, 2011 Report Posted May 22, 2011 Bolt in replacement. I hear that finding the correct 2.25 rack can be tricky though. Autozone shows listings for a "sport" rack, I believe that's what another member said. Rockauto also lists a 2.25 turn sport rack, ATSCO #64139 for $128.79 plus a $79 core. Quote
johnny404 Posted May 22, 2011 Author Report Posted May 22, 2011 yep atsco rack thats what im doing looks like a no brainer and then prob set of kyb gr2 struts all the way around Quote
94 olds vert Posted May 22, 2011 Report Posted May 22, 2011 I put a TGP rack in my car. Bolts right in. It's kind of a pain to get the rack in, but its not all that bad. Quote
jman093 Posted May 23, 2011 Report Posted May 23, 2011 Does your car have EVO steering? I think the RPO is NV7. If so the TGP rack won't have it. It is possible to get 2.25 EVO gear as they came in later w-bodies (my GTP has one with a blown up pinion bearing), but they are only available AC-Delco and cost like $500. Quote
johnny404 Posted May 23, 2011 Author Report Posted May 23, 2011 NOT SURE WILL HAVE TO CHECK THAT OUT SEE WHAT RPO IS Quote
alec_b Posted May 25, 2011 Report Posted May 25, 2011 In his vert wouldn't the EVO solenoid be on the pump not the rack? I thought only the later models had the solenoid on the rack. Quote
jman093 Posted May 25, 2011 Report Posted May 25, 2011 In his vert wouldn't the EVO solenoid be on the pump not the rack? I thought only the later models had the solenoid on the rack. Yeah, its on the pump and the later Magnasteer systems were on the rack, but I know for a fact the part numbers are different for an EVO vs regular steering rack. Thinking about it, I guess I may be wrong in saying that the TGP rack won't work. I suppose it very well could work. It won't be right, but it may work nonetheless. Quote
