94 regal gas tank door
the door closer has broken,it is piece of spring steel, so no tension on the door and it doesnt shut firmly, How do I repiar or replace it?
You could replace the hinge, but the nuts are kind of annoying to get to, behind the wheel well splash shield if I recall correctly.
Yea, ive looked in the opening and it appears that section of splash shied is riveted in, Ican see one screw were hinge mounts to bracket..sound like junk yard part.
