1997 Grand Prix GT transmission slow shift for second into third gear
i was wondering if the fuel pressure sensor has anything to do with this? some of the problems are it knows its suppose to shift, it kind of goes into neutral but still speeds up then shifts at a much higher RPM. any idea what it could be?
Fuel pressure sensor? Or do you mean regulator? Could be a number of problems. What motor is this?
L36 doofus. 4t60-e trans.
I would not think its fuel related. Sounds like the trans is slippin.
Either that, or the vacuum modulator on the transmission is shot. Might be worth a look, modulators are cheap.
its the 3.8L and its weird how it shifts like it knows its supposed to and fakes the another 2000 RPM it finally does. could bad fluid be the problem too
Isn't that gonna have a 4T65-E? Even gen 1.5 cars got them in 97. It might have the 4T65-E bad pressure solenoid problem.
and i think this car is the last year for the 4t60e behind a 3800 in a GP...
correct you are. 97 GT's and all SE's got the 4t60-e.
