Sub hums with engine on
Why would my sub hum when the engine is running, but be fine when off
Its like something is coming through the stereo. It goes away for a second when I switch sources
does the tone change with different engine speeds?
Rpms. It sounded like I had a V8 :lol:
Alternator noise? Ground the head unit out your self. And Clean the ground for your sub.
nope, amp issue! Once I started messing with it I remembered that if I had the gain up a certain way it'd do that, so I just have to keep it below that spot. Works great now!
Most likely the amp is going bad, or you may have been turning the gain up to high. Although that usually doesnt cause engine noise, just clipping.
I ran that same amp for well over a year just fine, and it's doing fine now :dunno: I think something in the pot is messed up, but if I keep it under then it's just fine. That spot is a fair bit further up than I turn the gain up anyways
