Hey guys I am curious if w-bodies came with aluminum sub frames? I was wondering years makes and models, I swear I seen one laying on the ground at LKQ in rockford and it sparked my interest.
00+ impalas and Monte carlos did as well.
There are really more differences in these cars and the earlier 2nd gens that there are between gen 1 and gen 1.5 w's.
And ntrcool, if you're going to ask if it can be swapped, the answer is no unless you're able to fabricate real well.
Yeah, as much as it would be nice to swap one of these in, a far amount on fabrication on the front side mounts will be required. IIRC the rear mount locations are correct, the fronts I believe are wider and sit higher up.
The thought crossed my mind when I seen the one in the yard. but my budget is low for the year.:confused:
