Laveen Z34 Posted May 4, 2011 Report Posted May 4, 2011 How can I take off the auto shifter knob on a 93 Z34 so I can take out the center console? Quote
Penglii Posted May 4, 2011 Report Posted May 4, 2011 There should be a staple shaped pin on the front facing side... pop that out and pull the shifter off. The staple shaped pin can simply be pushed back into place during reassembly. Quote
cutlass1991 Posted May 4, 2011 Report Posted May 4, 2011 not sure if the z34 is the same way, but in the 95 cutlass there was a little clip shaped like a U that is pushed into the shifter knob. Look around the base of the shifter knob and if you find it, just pull it out with a pair of needle nose pliers. Then then knob just lifts straight off of the shaft Quote
