19Cutlass94 Posted May 2, 2011 Report Posted May 2, 2011 Hey guys, I just swapped out the Multec 1 for Multec 2 injectors. The Multec 2 harness I had, I used the injector connectors on my old harness. I matched up the connectors, wire for wire ( which was easy because GM used difference colored wire for each plug ) and those matched between the two harnesses. I soldered every connection then heat shrinked it, I put everything back together, and now I have a no start condition. Ive tried several BIN's and all do the same thing. The SES light doesnt go off with ignition on. and check gauges light doesnt go off either. What could have gotten messed up to the point where its now like this? Quote
Andrew Posted May 2, 2011 Report Posted May 2, 2011 what are the respective impedence and lb/per hr ratings? Quote
Crazy K Posted May 2, 2011 Report Posted May 2, 2011 ?!?!? Why did you do that? ARe you getting your car tuned to run them? Quote
RobertISaar Posted May 2, 2011 Report Posted May 2, 2011 ?!?!? Why did you do that? ARe you getting your car tuned to run them? Jay ran out of injector. the 22.5s should give more room to play compared to the ~19.5 that were there. Quote
BXX Posted May 2, 2011 Report Posted May 2, 2011 Err, 3100 L82 injectors are fricken tiny, 17lb/hr Quote
RobertISaar Posted May 2, 2011 Report Posted May 2, 2011 17.4 at 43.5 PSI, but he had them hooked up to a 55 PSI regulator, pushing them into the ~19.5 range. Quote
Jonpro03 Posted May 2, 2011 Report Posted May 2, 2011 Are they the same flow rating? I remember I swapped out 20lb/hrs with 24lb/hrs once thinking it would be ok, but it wouldn't even start unless it was WOT. Are you batch fire or SFI? Quote
19Cutlass94 Posted May 2, 2011 Author Report Posted May 2, 2011 yeah they are all the same flow rate. These injectors have been sitting for years. So im thinking that either there stuck open or they are shit. I didnt OHM test them before I put them in which I should have... Quote
19Cutlass94 Posted May 2, 2011 Author Report Posted May 2, 2011 Found the problem. Need new injectors. Quote
BXX Posted May 2, 2011 Report Posted May 2, 2011 Sometimes the simplest explanation is the correct one:lol: Sucks that you need new injectors, but it beats a pinched and damaged wiring harness that it coulda been. Quote
19Cutlass94 Posted May 3, 2011 Author Report Posted May 3, 2011 yeah well I completely redid the harness. Ive got power going to all the injectors, but i guess after yrs of sitting, they said fuck you im not allowing fuel into your cylinders! What #/hr are they? Quote
Jonpro03 Posted May 3, 2011 Report Posted May 3, 2011 (edited) They're 19lb/hr at 43.5psi, that's 22 at 55psi. They ran 90% duty cycle at 2psi boost on my 3500. EDIT: I guess they're 19lb/hr at 39.6psi or 22.4 at 55psi. $30 shipped and they're yours. Edited May 3, 2011 by Jonpro03 Quote
19Cutlass94 Posted May 3, 2011 Author Report Posted May 3, 2011 Cant use them. I just swapped over to the Multec 2 clips on my harness. So Ill need Multec 2 injectors. Other wise Id use em though! Quote
Jonpro03 Posted May 3, 2011 Report Posted May 3, 2011 No worries. I thought I had some 3500 injectors (multec2s), but I threw them away a couple of weeks ago. Quote
BXX Posted May 3, 2011 Report Posted May 3, 2011 I have LX9 injectors still, but they are the little bastards:lol: Dunno if those will work Quote
Jonpro03 Posted May 3, 2011 Report Posted May 3, 2011 Good point. If you use lx9 injectors, you will have to modify your rail. Quote
