Jonpro03 Posted April 30, 2011 Report Posted April 30, 2011 (edited) .. Edited May 18, 2011 by Jonpro03 Quote
White93z34 Posted April 30, 2011 Report Posted April 30, 2011 Save yourself some time, its almost 100% the sending unit. 97' were supposedly bad for that. my 97' Bonneville did the same thing when I got it, it was the sender. Quote
Jonpro03 Posted April 30, 2011 Author Report Posted April 30, 2011 (edited) .. Edited May 18, 2011 by Jonpro03 Quote
AL Posted April 30, 2011 Report Posted April 30, 2011 I am getting 2 different resistance values depending on which part number is on your sending unit... There is a TSB on it actually File In Section: 8 - Chassis/Body Electrical Bulletin No.: 83-83-07 Date: March, 1998 Subject: Fuel Level Sensor Replacement Procedure Models: 1997-98 Passenger Cars and Light Duty Trucks (Listed in Application Chart) INFORMATION This bulletin is being issued to clarify that, when fuel gauge diagnosis per the Service Manual indicates the cause to be the fuel level sensor, complete fuel sender assembly replacement is NOT required. Available fuel level sensor service packages are indicated in the application charts and should be installed following applicable Service Manual procedures and those provided in the service packages. Quote
AL Posted April 30, 2011 Report Posted April 30, 2011 Ill post a pinout for you when I get back inside Quote
