Addicted2bass Posted April 28, 2011 Report Posted April 28, 2011 Im planning on putting a new steering rack in the TGP. I know the rack is differant from a regular Grand Prix. Autozone seems to be the only place that lists multiple racks. http://www.autozone.com/autozone/parts/1989-Pontiac-Grand-Prix/Rack-Pinion/_/N-ihk17Z8oxk3 Looks like I need either the 64139 or 6453 depending on whether my car has 2.25 or 2.75 turns from lock to lock. Are these the TGP racks? Quote
Addicted2bass Posted April 28, 2011 Author Report Posted April 28, 2011 Im assuming a non "sport" rack would give me more power assist? I like to buy from Napa becasue I get a good discount however they only list one rack. Autozone is the only place I can find that lists a "sport steering" rack. Quote
Garrett Powered Posted April 29, 2011 Report Posted April 29, 2011 autozone will probably send you the wrong one. Quote
Addicted2bass Posted April 29, 2011 Author Report Posted April 29, 2011 Got one from Napa today. Its the 2.25 lock to lock rack. Anything I need to know about putting it in? My friend who is a mechanic is helping me since i've never installed a rack and pinion before. Quote
virtuetovice Posted April 30, 2011 Report Posted April 30, 2011 Im assuming a non "sport" rack would give me more power assist? The sport rack is just "tighter". It takes less of a steering wheel turn to make the steering rack travel further. I don't think there's a difference in terms of steering "power" between the two. Edit: I would use new power steering lines. Quote
Addicted2bass Posted May 3, 2011 Author Report Posted May 3, 2011 Yup got new power steering lines. Well one line, the return line is no longer avalible. But we should be able to use regular low pressure line for that if we need to. Quote
Crazy K Posted May 3, 2011 Report Posted May 3, 2011 Set your toe straight(front tires parallel) with a tape measure once you have the rack in... then get alignment? When I have used screw fittings like at the end of the line, i always coat the surface where the line and fitting meet to prevent rusting and thus difficulty in future removal, if needed. Make sure you bolt the rack in, unlike the rack that Bob's vert had when I got it? Sometimes the joint that attaches to the rack is a bit too tight to slide on. I have used a 7mm typical interior screw and screwed it into the cut gap on the edge of the joint to spread the gap so that the joint slides on with ease. once on, remove the screw. need more advice? Quote
Addicted2bass Posted May 4, 2011 Author Report Posted May 4, 2011 Thanks Ken. We should be good. A friend of mine is helping me, hes a mechanic and has done racks before. I have you're number so if we run into any problems ill give you a ring. Quote
white4d96 Posted May 5, 2011 Report Posted May 5, 2011 Hm... wonder if the TGP rack would go into other GP's... Quote
Penglii Posted May 5, 2011 Report Posted May 5, 2011 The TGP rack will install, at the very least, into any 1st gen W-body... It's just the lock-to-lock ratio that makes it so special. Quote
White93z34 Posted May 5, 2011 Report Posted May 5, 2011 I have a TGP rack in my z34, in addition to the 2.25 it also has less assist which gives the steering a nice feel IMO. Quote
Addicted2bass Posted May 5, 2011 Author Report Posted May 5, 2011 Well we ran into larger problems then the rack. Turns out the passenger side front subframe mount rotted away and the drivers side doesnt look like its following to far behind. im having problems locating new mounts. If anyone has any advice heres my thread on it: http://www.w-body.com/showthread.php/50632-Rotted-out-subframe-mount. Thanks. Quote
Mach 5 Posted May 9, 2011 Report Posted May 9, 2011 gm has new mounts and autozone can get you the power steering hoses. go online to autozones website. I actually just bought all new lines from them along with the mounts from GM Quote
Addicted2bass Posted May 10, 2011 Author Report Posted May 10, 2011 The GM dealership I went to could order everything new except the body to frame mounts which are discontinued. I ended up getting everything from a member on here. I got power steering lines from Napa, but the ones in there were perfect so we didnt end up doing them. Quote
