bve32k Posted April 25, 2011 Report Posted April 25, 2011 Hello all, I have a 95 GP..The seal around the rear window is starting to pop out on the bottom corner of the driver side. How do I go about fixing this? I can push it back in, but then it will pop back out. I am getting water in the trunk also..I believe it is from this area. Thanks, Ken Quote
npfd Posted April 27, 2011 Report Posted April 27, 2011 Hey there, Just fixed problems like this on our 97 CS, sedan, still have one more. What worked for us was to remove the weatherstripping, chisel off the plastic holding clips and use urethane windsheild caulking to fill the gap, and smooth it out. Maybe you'd want to try removing it putting the caulking then reseat the weatherstripping. I read up on a flowable sealer, which may help too. You are sure the leak is from there? How's the weather seals for the trunk? I had a problem at the back corners of the trunk, needed to RTV between the metal joints, and the electrical connector on the passenger side where all the rear wires head out. To be sure use a hose hehe... Hope this helps. Quote
