steering wheel controls w aftermarket stereo
anybody got idea how to put an old school alpine head unit and eq into a 1995 cutlass vert and retain steering wheel controls (at least for the climate control part if not both)
If the Alpine has a steering wheel control input you can use a interface like the Metra ASWC to retain steering wheel controls.
have looked at pac and have an email sent to their tech support dept,waiting for reply
If the headunit has the headphone jack connection then you can use the pac or the axxess ASWC
http://www.pac-audio.com/productDetails.aspx?ProductId=207&CategoryID=29
If the headunit came with a remote and does not have the proper connection for the SWI-Jack then you can use the
http://www.pac-audio.com/productDetails.aspx?ProductId=212&CategoryID=29
You can also check on crutchfield to see which interface works with the alpine headunit that you have.
i used the PAC unit in my 2002 monte carlo when i did my stereo install, works out nice. No complaints so far!
  • 3 weeks later...
does anybody have a pinout of the steering wheel controls for the 1995 cutlass supreme and also the radio that goes with it?
I have the factory service manuals for the '95 Cutlass, I'll take a look, and let you know. :thumbsup:
thank you very much it seems like it should be easy,what i want to do here
Johnny; some behavior issues with my 17 year old son kept me from the service manuals last night, I'll try again today to find what you're looking for.
Sorry, wrong pic..
Edited by Galaxie500XL
Same here.
Um, just ignore those pics...they WERE the pinouts for the connectors at the steering wheel, and the radio, I had gotten them from the Web...but for some reason, they're something TOTALLY unrelated now, which I suspect is deliberately done by the source.
well the way i see it it can only be a switched ground kind of thing so if i supply the heat/a/c switches what they need then they will work,right?
the head unit is old and has no provisions for this so i know that going in
