biddieboi Posted April 16, 2011 Report Posted April 16, 2011 Hey guys i have a problem with my 1996 chevy lumina stereo. Here is the problem. My stereo works sometimes. when i am listening to music which isnt to loud but i have to turn it down before i shut the car off. Thats because when i get back into the car the factory stereo turns REALLY loud and DISTORTED and then blows out all the speakers temporary. After a few hours or a day or two the factory stereo and speakers start to vaguely work. But i have to keep it down because it will just repeat itself and it all started when i simply replaced one of my blown rear deck speakers. what do i do? what do i check? am trying to save a little money but should i go ahead and just replace everything? any advice would help. thanks in advance. Quote
RobertISaar Posted April 16, 2011 Report Posted April 16, 2011 which stereo do you have? IIRC, there were 3 available in 1996. Quote
BXX Posted April 16, 2011 Report Posted April 16, 2011 What speaker did you replace the original blown out one with? From the sounds of it, you either put a low ohm speaker in place or the replacement speaker is bad causing low resistance causing the issue, or the most likely cause is that the wiring right at the speaker is hitting chassis ground which pisses everything off:lol: Quote
virtuetovice Posted April 16, 2011 Report Posted April 16, 2011 I've found that wiring the speaker backwards can actually cause a lot of problems in some stereos...be sure to double-check your wiring. Quote
BXX Posted April 16, 2011 Report Posted April 16, 2011 I've found that wiring the speaker backwards can actually cause a lot of problems in some stereos...be sure to double-check your wiring. Wont on that HU. I can 99% guarentee he has the wiring or speaker terminals shorting out to the chassis or the other 1% says the speaker is bad. Quote
biddieboi Posted April 17, 2011 Author Report Posted April 17, 2011 Wont on that HU. I can 99% guarentee he has the wiring or speaker terminals shorting out to the chassis or the other 1% says the speaker is bad. But i didnt wire it wrong i just plugged in the connection forthe rear deck speakers. Basically just swapping one speaker out. But how to find out if the speaker terminals are shorting out on the chassis? I probably just will need to replace everything from stereo to speakers. Its the stereo that has a tape player dont know if that helps any. but the rear deck speakers dont even play at all now. and it is not touching anything but am a go an recheck. Quote
Addicted2bass Posted April 20, 2011 Report Posted April 20, 2011 Check all your speakers with a multimeter. They should all be around 4 Ohms. If you have one that is not around 4 Ohms then that is the speaker causing your problem. Quote
biddieboi Posted May 27, 2011 Author Report Posted May 27, 2011 so if it has more or less then 4 ohms of resistance then that speaker is bad? an my factory radio is just shot. so shoppin for another one. Quote
White93z34 Posted May 27, 2011 Report Posted May 27, 2011 Check all your speakers with a multimeter. They should all be around 4 Ohms. If you have one that is not around 4 Ohms then that is the speaker causing your problem. I always thought most of the factory stuff was 8-12ohm Quote
birdman Posted May 27, 2011 Report Posted May 27, 2011 No its usually 4ohms or less, most home stereo equipment is 8ohms. Quote
RobertISaar Posted May 27, 2011 Report Posted May 27, 2011 IIRC, the factory 6 X 9s in the MC were 4 ohms... i believe the 5 1/4 up front were as well. Quote
Addicted2bass Posted May 27, 2011 Report Posted May 27, 2011 I always thought most of the factory stuff was 8-12ohm I have seen 1,2,4 & 8 ohm speakers in cars. 4 is by far the most common though. The others are usually running off a factory amp. Quote
xtremerevolution Posted May 27, 2011 Report Posted May 27, 2011 Pretty much what everyone else said. Running the wires backwards on a set of speakers will do nothing but cause them to run out of phase. When you have one speaker running out of phase, it will start to cancel the other one out at certain frequencies depending on how far away you are. Quote
Starflare5 Posted July 27, 2011 Report Posted July 27, 2011 (edited) Hey guys i have a problem with my 1996 chevy lumina stereo. Here is the problem. My stereo works sometimes. when i am listening to music which isnt to loud but i have to turn it down before i shut the car off. Thats because when i get back into the car the factory stereo turns REALLY loud and DISTORTED and then blows out all the speakers temporary. After a few hours or a day or two the factory stereo and speakers start to vaguely work. But i have to keep it down because it will just repeat itself and it all started when i simply replaced one of my blown rear deck speakers. what do i do? what do i check? am trying to save a little money but should i go ahead and just replace everything? any advice would help. thanks in advance. Hey there, Is your factory head unit the type with the cassette player in the top middle, and the display to the right side of the unit? If it is, remove the unit and check the rear wiring. Check to see if any wires are comming in contact with the dark green wire. This wire is E&C data buss which also controls the speed controlled volume. Just check that out just in case. Hope this helps, Starflare5. Edited July 28, 2011 by Starflare5 Quote
