jeremy Posted April 14, 2011 Report Posted April 14, 2011 Hmmm, cutting off a few inches before the filter? Decent idea, but I think the other side is also shot, I'm trying to see where that's leaking I actually meant getting the entire line from the engine bay to the filter. I can't imagine driving a car with a ghetto fabulous rig-job on fuel line. I would rather walk. Quote
Psych0matt Posted April 14, 2011 Author Report Posted April 14, 2011 It's solid for now, I may mess with it more, or more likely I'll start looking for a new DD. Just dumb cuz the engine runs great Quote
Timm Posted April 14, 2011 Report Posted April 14, 2011 At my work, we sell small sections of fuel line repair items, a 3/8 fuel line with the male fitting on the end comes in 8, 18, or 36" sections, it's barbed on the end to put a fuel line on, but we usually just sell the customers a 3/8" compression fitting. Works great! (and usually under $20!) Quote
Psych0matt Posted April 16, 2011 Author Report Posted April 16, 2011 well I think I figured out what I need to do as a more perma-fix. I'm gonna get a section of solid fuel line (I believe they have that at AZ?) and put some fittings on the end of two pieces, so that I can use the new stock filter I got, and then use a piece of hose over the splices. That way if I ever sell it it's still using the stock filter, and will probably be easier to get off (cuz you can just loosen a hose clamp or two and do it on the bench ). I'm gonna take it in to work with me today to see what needs to be done, maybe I can get it all set up so tonight after work I can take 10 minutes and throw it on Quote
Addicted to eaton Posted April 16, 2011 Report Posted April 16, 2011 just get a fuel line hose (its ment for gas and pressure) then get a jeep filter from a 1996 Jeep charakee (sp) its for high pressure and use's rubber fuel lines! Quote
