ZeeQuick Posted April 12, 2011 Report Posted April 12, 2011 Just tonight I lost both my gauge cluster lights and rear lights. The brake lights work, but with my headlights on none of the interior gauge/radio/climate/window switch lights are on and neither are the rear lights. Fuse?? Hopefully something easy (fingers crossed) Quote
npfd Posted April 12, 2011 Report Posted April 12, 2011 Off the top of my head, maybe light switch itself? I'm more familiar with the 1 gen light system... I don't know if it changed for the second.. you checked the fuses also? I know on the 97 CS, DRL module, etc.. is underneath the driver side kick panel, maybe check connections in there? Quote
Addicted2bass Posted April 12, 2011 Report Posted April 12, 2011 Most likely a fuse. Check all your fuses with a test light. If it just blows again there must be a short somewhere. Quote
5speedz34 Posted April 12, 2011 Report Posted April 12, 2011 Could also be a bad ground. I had a bad ground do similar things. Quote
ZeeQuick Posted April 13, 2011 Author Report Posted April 13, 2011 Yup, replaced the fuse and its all good again. Here's hoping it doesn't blow again. Thanks guys! Quote
Thundernuts1979 Posted April 14, 2011 Report Posted April 14, 2011 (edited) I had that problem with my 91 buick century all the time...of course having a 5 ft wide tail light didn't help...Dielectric grease in the bulb sockets stopped all the shorts for me....luckily it sounds like just a fuse for you Edited April 14, 2011 by Thundernuts1979 Quote
ZeeQuick Posted April 16, 2011 Author Report Posted April 16, 2011 Yup, on the way to work today the lights went out again.....ugh Quote
