tonyo Posted April 10, 2011 Report Posted April 10, 2011 2003 monte carlo 4t60e does not shift into 4th gear or overdrive sometimes on the highway someone said adjust the neutral safety switch so that it will start in neutral and park could this be? or the brake switch could be out of place push it back where it should be Quote
Schurkey Posted April 11, 2011 Report Posted April 11, 2011 2003 monte carlo 4t60e does not shift into 4th gear or overdrive sometimes on the highway someone said adjust the neutral safety switch so that it will start in neutral and park could this be? or the brake switch could be out of place push it back where it should be 4th gear IS overdrive. Do you mean it doesn't go into 4th gear and the torque converter clutch doesn't engage? Does it not start in neutral and in park??? It should. Brake switch can prevent TCC engagement. Quote
zipper Posted April 13, 2011 Report Posted April 13, 2011 You don't have a 4T60E, you have a 4T65E. Read this: http://www.tripleedgeperformance.com/No_4th_Gear.html It's a common problem with these tranny's. Quote
