9lumina6 Posted April 9, 2011 Report Posted April 9, 2011 On my way to pick up my sister today I was driving thru Irondequoit and in town randomly noticed my temp gauge was crawling up passed the 215 mark. It had never done that bfore...I turned the heat on full blast and it would stay steady right around 210. Every so often would go back down to ~195. Got on the expressway and the temp was normal....and then randomly even at 70mph crawled right back up to 215-220...then back down again. Bubble in the system...or bad thermostat? I did also notice the coolant tank was near empty. I just bought a 180 t-stat for it and will put it in once it cools down...and I'll add more coolant t the radiator while I'm at it. Any suggestions?? Quote
urbex Posted April 9, 2011 Report Posted April 9, 2011 Get a refund and beat the seller! Oh, wait.... Quote
AL Posted April 9, 2011 Report Posted April 9, 2011 WTF! Its possible it might be the water pump... I remember rich telling me his car went through 2 or 3 water pumps... But I don't know where I would start looking... Maybe check around for any external leaks Quote
urbex Posted April 9, 2011 Report Posted April 9, 2011 I'm assuming you've checked to make sure it's not in the oil? Quote
9lumina6 Posted April 9, 2011 Author Report Posted April 9, 2011 WTF! Its possible it might be the water pump... I remember rich telling me his car went through 2 or 3 water pumps... But I don't know where I would start looking... Maybe check around for any external leaks It has been leaking what looks to be coolant intermittently lately.......once in a while there will be a spot under the water pump area....I could never pinpoint the leak tho. And as for the overheatn issue....it was low on coolant....(low coolant light never has come on though). I just put a brand new 180 t-stat in and ran the car while filling the radiator and overfill tank. I used a good 3/4 of a gallon to fill it completely. Let it idle for 5 or 6 minutes and the temp stayed right between 180-190. I'm waiting for my other laptop to charge so I can change the fanpoints with the powrtuner, and then I'll take her out for a ride. Quote
9lumina6 Posted April 9, 2011 Author Report Posted April 9, 2011 I'm assuming you've checked to make sure it's not in the oil? I just changed the oil last wekend....and it did not look abnormal in any way. Quote
Andrew Posted April 10, 2011 Report Posted April 10, 2011 probably leaking at the coolant elbow. Quote
AL Posted April 10, 2011 Report Posted April 10, 2011 They are 40k and 2 years old... But I guess its possible Quote
9lumina6 Posted April 10, 2011 Author Report Posted April 10, 2011 The top coolant elbow is dry as a bone....I can't see the bottom one tho. I did notice today that it is damp just to the inside of the harmonic balancer.....wich is directly under the WP....I'm wondering if the WP gasket is on its way out. Drove it around this evening...everything is back to normal. Even sat in the McDonalds drive thru and the temp stayed right where it should. Quote
