gryfan Posted April 3, 2011 Report Share Posted April 3, 2011 1994 cutlass vert....3.4......does it have a timing belt or a chain? it has 55,000 miles on it. should it be replaced based on time (age) or should the factor be mileage? thanks in advance.... gryfan 1994 cutlass 'vert 1990 buick reatta coupe 2005 chrysler crossfire roadster 2007 sonata....winter beater gryfan burlington, ontario Quote Link to comment Share on other sites More sharing options...
White93z34 Posted April 3, 2011 Report Share Posted April 3, 2011 it has both. Chain is a lifetime part, belt should be replaced every 60,000 miles. most people I know have run them way longer then that though. Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted April 3, 2011 Report Share Posted April 3, 2011 Belt. I think the recommended change is 60,000 miles, but that is from the factory. There is a way to inspect it. I would do that so you know what it looks like. There is a black cover on the left side of the engine that has two 8mm bolts on. Take those off and the cover comes off and there is your timing belt. I would look for any fraying or missing pieces along the edges. Quote Link to comment Share on other sites More sharing options...
gryfan Posted April 3, 2011 Author Report Share Posted April 3, 2011 it has both. Chain is a lifetime part, belt should be replaced every 60,000 miles. most people I know have run them way longer then that though. white93z34, first off thanks for the info....and man you are fast in you response. cheers, gryfan Quote Link to comment Share on other sites More sharing options...
gryfan Posted April 3, 2011 Author Report Share Posted April 3, 2011 Belt. I think the recommended change is 60,000 miles, but that is from the factory. There is a way to inspect it. I would do that so you know what it looks like. There is a black cover on the left side of the engine that has two 8mm bolts on. Take those off and the cover comes off and there is your timing belt. I would look for any fraying or missing pieces along the edges. thanks for the great info.......really appreciate it. cheers, gryfan Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted April 3, 2011 Report Share Posted April 3, 2011 (edited) My old 91 International had almost 110,000 kms on it IIRC when I sold it to Jamie, it has the original timing belt which still looks great at 20 yrs old (although you have to wonder what age and heat does to rubber) A good practice is to inspect the belt at every oil change. The carcass of the belt will usually start becoming narrower than the teeth (the teeth will appear to stick out wider than the carcass of the belt), indicating the belt is beginning to fail. Also, when you have the cover off inspecting the belt, fire the car up and watch the belt go around, making sure the belt is in good shape all the way around. You'll notice a fine rubber dust on the inside of the cover, I always wipe it out, and watch for increased accumulation or rubber dust showing accelerated wear next time you look at it. Edited April 4, 2011 by GOT2B GM Quote Link to comment Share on other sites More sharing options...
gryfan Posted April 3, 2011 Author Report Share Posted April 3, 2011 My old 91 International had almost 110,000 kms on it IIRC when I sold it to Jamie, it has the original timing belt which still looks great at 20 yrs old (although you have to wonder what age and heat does to rubber) A good practice is to inspect the belt at every oil change. The carcass of the belt will usually start becoming narrower than the teeth (the teeth will appear to stick out wider than the carcass of the belt), indicating the belt is beginning to fail. Also, when you have the cover off inspecting the belt, fire the car up and watch the belt go around, making sure the belt is in good shape all the way around. You'll notice a fine rubber dust on the inside of the cover, I always wipe it out, and watch for increased accumulation or rubber dust showed accelerated wear next time you look at it. thanks matt....great detail in that answer. cheers, gryfan Quote Link to comment Share on other sites More sharing options...
White93z34 Posted April 3, 2011 Report Share Posted April 3, 2011 The oem belt in my old euro didn't let go till 143,000 miles, and even then it wa a idler that failed not the belt, my old z I ran for 80,000mi on the belt that was on the car when I got it didn't let go till the tensioner acutator failed. Quote Link to comment Share on other sites More sharing options...
