Alternator on 93 z-34 .....3.4
Hey looking for some help with the removal of the alt. on this car, read the sticky that is posted great info went threw all the steps, but have one problem can't seem to get to the bolt in the rear of the alt. can't even see it for that matter .....how do you guys get to this bolt ....im right there just need this one removed ....do I need to drop the exhaust or am I missing a step here ....thanks for any help with this one .....Cessna
you likely won't be able to see it, it should be a little 10mm on the back of the alt a small ratchet or box end wrench should be able to get at it no problem.
and I'd venture to say 90%+ of the people who do that job never put that bolt back in,
welcome to the forum!
thankyou ....I dropped the sub down a couple of inchs and I could'nt see the bolt I can barely get my hand up in behind the alt I'm a little uncomfertable dropping the sub to far down thinking that I might break something else ....like vaccum lines or any other line for that matter .....im only lowering the passenger side down did'nt see the need to drop the whole thing so thats what im saying about missing a step somewhere .....but thanks again and I will see if I can feel around and find that bolt ..........
You dont have to lower the whole subframe, only the one corner so your ok there... But it is a huge pain getting that top bolt
Man you ani't kiddin about reaching back there blind ...it took a little while but its done now .piss poor design on this alt ..needless to say top bolt did'nt go back in .thanks for the great help from everyone here ..........................................
  • 2 weeks later...
A mechanic friend of mine just did an alt. on a v-6 Escape, like 10 or 12 hours, and hes a pro. mechanic.
  • 3 weeks later...
Yep I replaced my alternator AGAIN recently, I think the upper bolts are easier to get to if you remove the coil pack.
