Are the x-laces 16x7 115mm? what's the offset, I am looking to get aftermarket and wana make sure I get something that is going to work with no modifications.
16 X 8, 115 X 5 pattern, with something like a ~25mm offset?
The stock is 25mm. You should be able to run up to a 40mm offset... 42mm offset might be pushing it with a 8" wide wheel.
i'm not a fan of the way bigger rims and their weight affect the handling of these cars. My GP handles WAY better w/ my 16's on there and some sidewall to give a little than it ever did w/ the 18's w/ less sidewall. The rims were heavy plus the weight was now farther out from center thus slowing accel and increasing the braking distance.
The best decision I did for ride and handling was go back to the 16x8 stockers.....now if I could find some good 17x9 wheels w/a +30 offset and a lip...i'd be in heaven.
And thats why the best handling cars in the world roll on 16" rims with big sidewall tires:lol:
You cant sum up your car all in one. Ever rim weighs different, and even moar important, what tire (for handling) and the weight of the tire.
the 18" tire I ran was very close in weight of the 16" tire I have now. The wheels....vastly different. The lighter the combo, the better....or why else are light suspension parts so sough after....ex: control arms, strut assemblies, etc.
Yes, they will work, but w/ that offset, they will be set in to the fender well and not be very flush. may look weird.
  • 2 weeks later...
There's many more variables than just the spacing between the hub and teh car, I'm pretty sure that I've seen 40mm offset rims that are 100% incompatible with our cars because of backspacing.
