light control swtch overheating (smoking) 94 cutlass supreme
I have some electrical problem with my 94 cutlass supreme s
i noticed smoke coming out from the driver side dash, i pulled the cover and noticed it was the light control swtich that was smoking, over heating for some reason. Can someone tell me which fuse controls this control swtich(i know its in the glove compartment). i think it maybe a higher fuse allowing it to overheat.
thanks
Edited by Steel Head
Even if the fuse rating is too high (allowing too many amperes through to the switch) you may still have a problem, ie the fuse will constantly blow because there's a problem with the switch (which, since it's smoking, you can bet there is now).
I replaced the switch, it works except my instrument panel light arent working.
