Guys, getting a problem with the parents 2001 Monte Carlo SS that I cannot track down.
Battery and alternator are pumping out correct amperage and voltage.
However instrument cluster shows less than 8 volts present.
All door lights, headlights, radio, instrument cluster, and alarm are adversely affected.
It seems like low-voltage issues, but the battery CLEARLY shows ~12.9v from a multimeter test.
Any details on what the low voltage problem for the car's electronics can be? :think:
- Erik
Not sure if its the same, but in the Trailblazers and others of that platform, but when the gauge cluster goes bad, it will show low voltage on the dash
I thought this initially too but he says the interior lights, etc. are affected. I've normally found it to be a crappy ground issue.
Been through the grounds inside the engine bay with no success.
I'm up for any and all ideas of what it could be.
- Erik
Solution Found: FAILED engine control unit (ECU).
Cracked board and some bad soder points...
Replaced for new ECU and car start and runs excellent.
- Erik
- Erik
Would've been one of the last places I'd have looked. Don't really see too many PCM
caused issues.
