Doing rear struts on 1st gen. I'm wondering about the auxiliary springs keep them on remove them what have you guys done i think if I found an auxiliary spring compressor id be more interested in keeping them
i left them out seems like the ride is softer and more comfortable........ weird
You only need a bolt to compress those springs, and not one of the compressor tools they used to make for them. The bolt size you need is M10 x 1.5 x 90mm in length. They're usually included in a lot of rear strut packages.
Your ride quality change is probably just due to the new struts. Here's a good quote from Shawn(GnatGoSplat) that sums up how things are without the aux springs.
The aux springs give a progressive nature to the stock leaf. It softens the small bumps without having any effect on larger bumps.
I pulled mine, because their brackets were in the way of the 94+ rear calipers. Mine were the cylindrical type, not the figure 8 style, so I don't know what's better or why, all I know is they don't make brackets to fit the cylinder type with the 94+ rear calipers or else I'd put them back on.
Removing them definitely stiffens the ride, as well as raising the ride height.
I need to get ahold of some that fit with 94+ rear calipers so maybe my rear "lowering spring" will actually look like one.
So removing them wont harm anything?
Do you have a sway bar? I would add a sway bar as part of the conversion process....
You're not going to harm anything by not having them installed. My 1993 grand prix has been without them for 9yrs.
gpchris they are on the rear suspension they are made of rubber that are mounted in between a bracket bolted to the strut and the mono leaf i dont have a pic but i think you can find 1 on here if you dig alittle
