19Cutlass94 Posted May 15, 2011 Report Posted May 15, 2011 Looking good! Cant wait to see the final result! Quote
kuntzie Posted May 18, 2011 Author Report Posted May 18, 2011 GOLD! clutch on, flywheel on, release bearing ready for my braided lines to come in, safe to say im the only 284 with a push style clutch, look how tight those clearances are in there! so much measuring and number crunching to make it all fit, rundown: custom made flywheel locally, tilton triple disc clutchs in sintered metallic, tiltion 1.44" height 8000 series slave cylinder (459$ :S) -3AN fittings and stainless braided teflon lines, the master is stock with a braised -3 fitting on it aswell so no plastic or rubber lines also, this trans has under 55k miles on it, so clean! Quote
Mach 5 Posted May 18, 2011 Report Posted May 18, 2011 interesting! what you using for a master?? Quote
kuntzie Posted May 18, 2011 Author Report Posted May 18, 2011 the master is stock with a braised -3 fitting on it aswell so no plastic or rubber lines Quote
kuntzie Posted May 23, 2011 Author Report Posted May 23, 2011 using a gen 3 aluminum subframe, have to fab mounts as theres no mounting spots for this trans, Quote
kuntzie Posted May 25, 2011 Author Report Posted May 25, 2011 got my spacer for between the engine and trans, 3/8" thick, the axles were already 1/2" longer then then "stock" last year as my axle geometry can be pretty nuts, so this year ill be ruiing the hybrid passenger one and a stock length drivers axle, will be perfect. also did some cosmetics.. cleaned up all my wiring, everyting is spereated, powers, rca's speaker wire, and the air ride stuff. you can see the power wire (1/0 ga) running down the drivers side also, you cant be a cool turbo build without some ubber clean interior... charcoal carpet.. was a late night, sorry about crap pic and seats.. i had the 04 cloth in there last year but accumulated 2 sets of leathers in the last month, im taking the best of each set and putting them in my car, removing the air bags, power portions, ect to lighten them up a little and then selling the other remaining seats. the parts on the seats are for a turbo install i am doing for a customer., just got them back from the powder coater. Quote
kuntzie Posted May 27, 2011 Author Report Posted May 27, 2011 update again intermediate shaft to engine block mount, triangulated, this will be excellent. ready for powder the trans mount is wraped around the subframe in a U shape, hes a few more pics. clutch slave lines ran, you can see the gromet for the one line, the other will be going through the inspecton cover which is made of rubber aswell i made this bracket to keep the release bearing from spinnig on the base, on the top ill be using a P clup to keep the braided line down thats why its not tightened yet. engine and trans will be bolted onto the subframe tomorrow and may get put in the car if i get the chance. Quote
mra32 Posted May 27, 2011 Report Posted May 27, 2011 you should take the pistons and crank out of your mock up block, you might even be able to move it around by yourself if you did that Quote
kuntzie Posted May 27, 2011 Author Report Posted May 27, 2011 just saw your pm, it will take 450wtq all day long forsure. and oil filter adapters are easy, i have a spare i could sell even.. btw i can lift that block with the pistosn and everything in it. Quote
xtremerevolution Posted May 27, 2011 Report Posted May 27, 2011 kuntzie said: just saw your pm, it will take 450wtq all day long forsure. and oil filter adapters are easy, i have a spare i could sell even.. btw i can lift that block with the pistosn and everything in it. Funny how easy they are, yet when I had multiple ongoing threads about it before I sold my 282, nobody had a straight or clear cut answer including you. Quote
Addicted to eaton Posted May 27, 2011 Report Posted May 27, 2011 umm... im pretty sure i posted a how to that my buddy did... Quote
stockgp Posted May 27, 2011 Report Posted May 27, 2011 given that you've already cracked the case on one 284, are you worried about weakening the case by drilling that hole for the line? Quote
xtremerevolution Posted May 27, 2011 Report Posted May 27, 2011 Addicted to eaton said: umm... im pretty sure i posted a how to that my buddy did... Yeah and it hardly looked easy to do. I guess if you're desperate to run a manual and a 3800, it can be done, but that's a different story. Quote
kuntzie Posted May 29, 2011 Author Report Posted May 29, 2011 the hole i drilled is only 1/2", theres many holes mush lager that were already on the case... and as mentioned before i didnt have the engine to trans bracket last year... Another update powdered engine to trans bracket on same day (friday) so i got it done with the colour my buddy was working with so i could get it back right away. engine and trans together with all lines ran and spacer installed on the subframe. Quote
Mach 5 Posted May 29, 2011 Report Posted May 29, 2011 very nice!! oh and I think the guy in the PT Cruiser is like woah watch the road... lol Quote
kuntzie Posted May 29, 2011 Author Report Posted May 29, 2011 this is the OFA i am using i also have this one thats just a modified stock unit with a remote filter Quote
kuntzie Posted July 10, 2011 Author Report Posted July 10, 2011 a bunch of udates in a row hee i forgot to post here the turbo i am going with is a turbonetics t76 Billet, ball bearing t4 divided housing, 1.3ar, with a soundperformance spool valvebuy, this will be the cats ass as for progress, was very busy, and had some more modifactions before installing. the holden intake uses a different tensioner and the power steering downt have a resovoir so there was no room for the stock PS pump and resovoir. i searched long and hard for a remote resovior from a gm, to keep as many GM partss as possible on the car, i found this this is a power steering resovoir from a chev optra, PERFECT! lower intake manifold.. Quote
kuntzie Posted July 10, 2011 Author Report Posted July 10, 2011 new hood, motors in, ready for the custom CT turbo kit now i transporterd the hood abut 100 miles on the roof of my monte, yay for carbon fiber and ye im still low Quote
kuntzie Posted July 10, 2011 Author Report Posted July 10, 2011 holden was just test fitting once again, for height and clearances with the hood, no issues. the upper intake is going to be modified to fit a 90mm ls1 TB, the holden stock tb neck will be cut off and the tb will flare out into a rectangle on the side of the uper intake to keep the same area as the 90mm TB, no bottle necking then for optimal flow. im going o be reinstalling the wire harness, mounting the Power steering resovoir, and cleaning up the engine bay tomorrow. i also have to cange the valve covers around. you can see how much free room the drive side has for the turbo kit now, can fit a 3.5" downpipe in with no problems it appears. i will be running stainless braided fuel lines in the car aswell, was getting the measurements with the intake and fuel rail in aswell. its been a fairly long proces but its finally getting there more pics tomorrow Quote
stockgp Posted July 10, 2011 Report Posted July 10, 2011 (edited) damn. did you rill the fender? looks like you'd rub like hell if you breathed on the car Edited July 10, 2011 by stockgp Quote
