high idle
threepointone
1st gen w 3.1 its doing high idle in park and neutral F and R seems to be normal any idea whats going on with this problem
Look for vacuum leaks. The engine looks to the MAP to determine idle, a bad MAP or vacuum leak could lead to high idle issues.
Ok I really need to replace the 3 plastic vac lines coming off the top of theTb can it still be purchased if so a part number would be great ill do some more inspecting of the vac lines and map
I'd definitely eliminate vacuum leaks first...way cheaper than MAP sensors... :biggrin:
Couldn't find any vacuum leaks with a stethoscope also visually. So I'm kinda stuck maybe try a new map sensor. Once its warm it seems to idle fine in park neutral. Something is for sure not right
