mra32 Posted February 8, 2011 Report Posted February 8, 2011 Does anyone have a list of the engine compartment grounding points for my 91 3.1/3 speed? I want to inspect them all. I also assume this is a good time to inspect the battery cables too and check the aux post. Quote
Garrett Powered Posted February 8, 2011 Report Posted February 8, 2011 PM me if you need a engine ground. I ordered some cast copper lugs and making one for Penglii already. yours should be like 1 ft long from block to near the battery tray. Quote
mra32 Posted February 8, 2011 Author Report Posted February 8, 2011 There is only one? I was gonna make some (one?) from stuff we have at work. Get some large gauge wire and solder a ring terminal to the end maybe plasti-dip it if i wanted to get fancy. And maybe try to use some sort of conductive paste on the grounding points (copper anti-seize?) Quote
94 olds vert Posted February 8, 2011 Report Posted February 8, 2011 On my car. There was one on the block and on the core support. Take the air box out and you can easily access both of them. I replaced both of my battery cables. Quote
mra32 Posted February 8, 2011 Author Report Posted February 8, 2011 I found 6 AWG. Big enough do you think? Quote
5speedz34 Posted February 9, 2011 Report Posted February 9, 2011 Take out your airbox and possibly the crossover(not necessary but makes it easier) and the bellhousing bolts with have most grounds for the harness. Otherwise like 94 olds vert said the radiator core. Quote
Garrett Powered Posted February 10, 2011 Report Posted February 10, 2011 ya I always put kopr-shield on the threads Quote
