Ok so I am no expert but I know a descent amount about cars. My father is a mechanic and I worked in his shop for 1 1/2 years, and I am an automotive refinisher/bodyman right now.
ANYWAY - my problem is with my 1992 Pontiac Grand Prix 3.1L - my idle is iffy. It will idle fine and then just all the sudden I will let off the gas or touch the brakes and it will die. It does not seem to be related to temperature, and I have searched high and low for a vacuum leak and cannot find 1. I replaced the IAC and the Throttle Position Sensor (it GREATLY helped my shifting issue but no help on the retarded idle).
I am about to do a complete overhaul and rebuild of the engine, but I would like to fix this before hand so it won't be a problem later.
Any ideas?? Thank you guy a ton
Check more basics, such as fuel pressure, spark and so on. Start small, easy and cheap and go from there. I know this is vague but oftentimes the simplest things are overlooked.
When is the last time you cleaned the throttle body?
MAP sensor maybe?
I cleaned it today actually, I took the IAC off and replaced it and broke the gasket for the connecting plate so I had to get the throttle body gasket set, and figured I'd just replace them all and clean it while I was at it. =/ I will look at the MAP sensor
