oil leak
threepointone
i know this has been posted before but on my 92 lumina 3.1 it has the oil leak at the oil pump drive seal . what gaskets should i replace and what all should be done when doing this job
Just clean the area really well and be sure to get the new brown silicone oil pump drive seal from GM... that one won't leak. Other than that, grab a throttle body gasket, its nice to have the TB out of the way when doing this job.
Ok good that's tomorrows job now I can use a good oil now that It wont be on the ground
just a follow up i had no problems doing this job i cleaned the throttle body and replaced the gaskets also replaced egr valve idle air control valve throttle position sensor air filter also oil pump seal and the throttle body coolant hoses so far no oil leakage runs ands idles smoother were ready for another 19 years
