hi, i recently bought a Z34 std. and i don't know how hard is to shift on these trannies but i think mine is a little bit hard so i would like to know if there is something i could do to improve that and also, what kind of care should i give to these trannies?? btw, the clutch seems fine because i dont have to press it very much, so i don't think the clutch is the problem, any comments would be appreciated. thx
Guest TurboSedan
try bleeding the clutch master cylinder. it's quite a bit different than my Getrag 282 5-speed tho, the Getrag 284 like you have is kinda funky from what i've heard and probably requires a different procedure to bleed. someone else here should be able to help you out... hth
joshua
