Christmas night I was driving when the car made a strange noise and stopped accelerating. I pulled over and let it sit for a while before I ran it through the gears. A little later, it was able to creep home while still making a horrible noise. When I had it towed to my fathers house a week later, it seemed that things changed. The noise can now only be heard while in park or neutral. It pulls strong in all gears except revers which doesnt seem to engage at all. Fluids were at the proper level but did seem to be a bit burned. Anyone know what exactly the problem is?
1996 Monte Carlo Z34
Edited by kolby
Whoa. Sorry for not putting that in the first place haha! It it a 1996 Monte Carlo Z34.
I'm going to go with Al here...those LQ1s eat transmissions like there's no tomorrow.
Damn. I was hoping that it wasn't shot and that I could fix it. I don't think I will go as far as swapping the transmissions, the car is a bitch to work on.
I mean, you could try a fluid and filter change, but it would be easier to just light $40 on fire and have the same result.
That trans is toast.
sounds like failure of a hard-part. Usually a failed reaction drum causes those symptoms but IIRC it takes out gears 2-4 as well...
My money is on a failed reverse band. Probably got hung up and was partially engage while the car was in drive causing it to break.
