Dannymik Posted October 8, 2003 Report Posted October 8, 2003 When our cars hit the middle age range things happen! This is what needed attention in my '95 Cutlass(within 12 months) 1.Front left signal 2.Battery 3.Rear pads/rotors/calipers 4.rear struts and mounts 5.new gas tank/tank straps/fuel filter 6.spark plugs/wires 7.pvc I still need to replace both inner ball joints, inner & outer left tie rod, a/c compressor, and a left fog light wire. Thats why GM is also known as Generous Motors Quote
91GranSport Posted October 8, 2003 Report Posted October 8, 2003 Here's a list of what I've done to my vehicle in the last 12 months: -oil change (Valvoline MaxLife 10W30, Formula 1 Filter) -four new tires (Motomaster Touring LXR 225/60R-16) Here's what I need to do within the next 12 months: -replace rear brake pads -replace all four struts/shocks -four wheel alignment -new bodywork/paint -new muffler Quote
J Posted October 8, 2003 Report Posted October 8, 2003 HA HA HA 12 months? full synthetic oil change Alt Starter Tie rods Ball Joints brakes all the way around x2 (including caliper,pads rotors) plugs weather stripping dual exhaust complete z34 kit including used parts, new hood razzi side skirts paint belt water pump gasket Lots more!!! Later all Jay this was all while in college and working for every cent of the money Quote
GPdriver1986 Posted October 8, 2003 Report Posted October 8, 2003 Most things need to be replaced such as alternators, water pumps, hoses, belts,tune ups,brakes etc. But if you get your car oil sprayed every year you won't have to replace things like brake lines, gas tanks, etc. I have had my car for 3 months already I got from a wreckers, it had new tires, new alternator, new battery, new coolant pipes. I had to do so much work for it to pass safety but that was because the car was not maintained. Quote
Thabulldog Posted October 8, 2003 Report Posted October 8, 2003 Lets get the memory out: Head Gaskets Paint Alternator Starter 4 Radiators... the reason im gunna start doing my own work Fans Upper and Lower Radiator Hoses Drivers Door and Fender Front Brakes Front Tires Added: Foglights Nozzle Lights to a dedicated switch Sound System Oil changes every 2000 miles so far That's all i can think of for now Quote
mjmich Posted October 9, 2003 Report Posted October 9, 2003 What kind/brand plugs and wires did you put on your 95 Cutlass? I'm changing mine next week. Quote
cutlassdude96 Posted October 9, 2003 Report Posted October 9, 2003 this year 2003 new front pads, new plugs and wires, alt., new intake gaskets, 2 oil changes Quote
sonyman87 Posted October 9, 2003 Report Posted October 9, 2003 my list so far not everything in the past 12 months but with int the past 18or so... t-belt serptine belt idle pullies altinator coolant line transmission coolant lines plugs wires x3 oil of course mobil1 transmission pan drop new tires new rotors breakpads X2 rear breakdrum work battery end of this month new suspension kyb gr2 all the way around end of this year new fuel injectors! another new set of tires! Things i ADDED flowmaser 40series street X2 + resignated tips to keep the sound from bleeding in the cab to bad. Magnaflow Cat. no resignator FFP dogbone ported stock box 3"pvc piping from box to intake Eram(dont say shit to me cuz it does work) My sound system 4 12s 1200watts walmart foglights! blue rxracing seat slips blue neon stringlighting blue rxracing windsheild sitcker blue lightning tub in the back window blue dragon floormants see a treand "blue" it goes good with the blue bow tie Quote
Redfox340 Posted October 9, 2003 Report Posted October 9, 2003 Monte Carlo: 3.8 Liter Series II [L36] Intake Manifold Bolt recall Jetta: none thus far! - Erik Quote
Dannymik Posted October 9, 2003 Author Report Posted October 9, 2003 As for plugs I put the A/C Delco rapidfires in and the wires I don't recall the name, I do remember that they are 7.5mm and are gray in color. I also did a coolant flush and about 4-5 oil changes withing 12 months Quote
AM6_Cutlass Posted October 9, 2003 Report Posted October 9, 2003 Last 12 months... Front brake pads and one caliper rear brake pads rear rotors alternator head gaskets/coolant flush and replaced with green stuff instead of dexcool oil and filter serpentine belt plugs and plug wires missing screw in door cladding low beam headlight (those things are $25!) still needs: oil and filter again front brake pads again (ruined by rotors) front rotors turn signal switch Quote
cmo1234 Posted October 9, 2003 Report Posted October 9, 2003 Nozzle Lights to a dedicated switch :?: So you just added nozzle lights to the ones built in the wipers or just drilled holes in the hood and put some dummy nozzles on... just wondering. Quote
Thabulldog Posted October 9, 2003 Report Posted October 9, 2003 About a week before i got the car painted i got out my drill and my biggest bit and tried as close as possible to line them up. I had to widen the hole quite a bit to get them to fit tho, and they arent bolted down cuz the top part of the hood is too thick for it to come all the way thru, then i wired them to the parking lights and ran a switch so when I get pulled over i don't have to hear that they are illegal cuz i can switch them off without shutting off my lights. Quote
99RegalGS Posted October 9, 2003 Report Posted October 9, 2003 last 12, Water pump 2 Belts (one because of water pump) Crankshaft position sensor (because of water pump) Intake coolant bypass fitting Pass. lower balljoint Very soon, Somthing in my ignition system Driver outer tierod Next year, Tires Quote
MommyTaz022200 Posted October 10, 2003 Report Posted October 10, 2003 Since July, since I haven't owned my car for 12 months... Replaced Front struts Rebuilt engine Front and back Calipers, rotors, pads Drivers side front control arm, and strut/Wheel assembly both mufflers/tailpipes Antenna (on it's way) heater core radiator Still need before winter tires back struts allignment leaf springs (?) starter Altinator There's probably more, for each thing I fix it seems 2 more things break Quote
Aaron Posted October 12, 2003 Report Posted October 12, 2003 fixed, not including mods, and you 3.1 guys think you have it bad :oops: -alternator 4 times, got it down to 4 hours!-140$ -knock sensor-85$ -Engine rebuild-3k$ and counting -Brakes-75$ -radiator fan-20$ -map sensor-124$ -clutch-1100$ -clutch with rebuild-450$ -ebrake-46$ -cruise control-30$ -egr-would be 200+, cleaned it for 20$ -power steering-35$ -oil cooler-110$ -there is more, but i just cant think of it right now. and aslo take into account i did all this myself, count in labor, and double everything. Quote
