Can both crankshaft sensors be tested with an OHM meter? I located one sensor mounted on the block that protruded into the block about 1 1/2 inches. I'm not sure were the other sensor is located. The sensor located in the block registered 1250 OHMs. I believe this is within tolerances. Any advice would be great.
1995 Cutlass Supreme 3.1
  • 2 weeks later...
The other crank sensor is behind the harmonic balancer and you can ohm them... I can get the specs for you tomorrow
