reprogramming key fobs
The key fob for my 97 doesn't work... I haven't replaced the battery yet but I didn't really think of this till now... Could I use my factory key fobs from the 03 on the 97? The numbers on the back of the fob for the 97 is GM: 10246215 and the ones on my 03 are 9364556-4575 but if I need to post the FCC numbers I will... So what would it take to reprogram the 03s remotes to work on the 97 or would I be better off getting a new remote for the 97 off ebay and reprogramming it
I think the 01+ fobs will only work on the 01+ cars. That's what I've been told at least. I think getting a 97-00 one would be your best bet
It's pretty easy, only takes a few minutes. It's in the owners manual if you happen to have one for the 97. If not I can get mine and copy it
That's good to know its in there... I found my owners manual last weekend so ill check it out... Thanks!!
Ill find out tomorrow if the instructions they have are correct... The owners manual skipped the first 5 steps lol
Well I tried that procedure on that website and still can't get the key fob to work... I tried 8 times probably... Do remotes just go bad randomly? Even with a new battery?
