OBD1 or OBD2?
topless94style
I have so many people telling me different things about my car. Which am I? Do i have the stupid hybrid with the obd1 connecter and obd2 computer?
The shape of the dignostic port is a good indication of determining your system:
Retangular = OBDI (like picture shown above via link)
Trapezoidal = OBDII
However, the OBDI Hybrid has (IIRC) the a rectanglar port but runs OBDII code / testing.
Have a look under your steering column and it should be easy to assess.
Bottom Line: If you can ground the system at home (w/o scanner) and read your own trouble codes, it's OBDI.
- Erik
um uh i did not notice both those links are the same hmmm i should have looked :lol:
um i can look in all data if you want me to i can try to see if it had 1 or 2 it might say i just don't know but i can try if you like
let me know
yea if you can check out all data that would be cool. i have the obd1 connecter i know that.
ok i will look inbetween classes i have to look up other shi too
i will look up 95 cutty with 3.4
yes it is obd 1 if it is 94 i have heard that 95 is the only year for the hybrid
