03 Grand Prix Brake Light Question
Brake lights don't work during the day, only the third brake light.
Bulbs are good, fuses are good, I assume switch is fine because it shifts into drive.
However they work fine at night.:think:
:mad:
Are your parking lights on at night?
I have DRL's since it's a Canadian car, so I just leave it in the "off" position and let it do it's thing at night. I'm pretty sure the park lights aren't on, it's just the headlights and fogs. To check, I just went out and threw the park lamps on manually, brake lights still not working.
Well it should have auto lights, and if your parking lights arent on then you most likely have 2 bad bulbs that need replaced... I have DRLs too
I replaced both bulbs.
What did you say happened when you turned on your parking lights?
Park lamps in the tails work but brake lights don't... hrmf, stupid car.
